Important info about realization:
- steel pipe, thick 3mm
- Seamless pipe
- All elements of laser-cut sheet
- Mounting - two points strap height and four support points on the longitudinal
- color depending on the customer's requirement (and availability) according to RAL
technically in accordance with FIA - Annex safety
Rollbar with one strut and hannesbar:
Rollbar with two struts (for requirement in red):
clear view
view through your mirror
we also have a douce
and on the car:
NEW ONE
rollbar with "X" struts
polished stainless steel version acid
and at this moment hit of this season - FROGG (original available only in US) :
on photo with harnessbar - originally without
if are you interested of a cost I can put it.
for each rollbar will receive a set of screws
Regards
Jaro
