Re: SPS Motorsport
#17
Here we have a really track focused NC. A 2.0L with a GT2860RS turbocharger making 270hp. The car is also very light. With 50% gas in the tank it weighs just 1122kg.
The rest of the specs:
- CSF radiator
- coilover suspension
- short differential
- brake cooling hoses
- Tarox F2000 with EBC YellowStuff
- rollover protection bar
- oilfilter relocation
- gearbox- and differential oil cooling system with external oilpump
- Rota Titan 9x17 with Nankang AR-1 255/40 ZR17
Best regards
Guido from SPS
https://sps-motorsport.com
https://sps-motorsportshop.com
https://facebook.com/SPSMotorsport
Re: SPS Motorsport
#18
One of my favorite cars on our site. Very clean oldschool setup.
The specs:
- 1.6L with a GT2560 turbocharger producing 230hp
- Mishimoto radiator
- oilcooling system
- BC Racing BR-series coilover suspension
- Lotus seats
- Sparco seat belts
- Momo steering wheel
- SPS Track+ roll over bar
- Rota RKR 8x15 with Nankang AR-1 205/50 R15 tires
Don't worry, we replace the sideskirts soon. ;)
Best regards
Guido from SPS
Re: SPS Motorsport
#21
Last weekend we had another TimeAtttack run, this time at the "Reisbrennen".
We had some issues with the white NA and the green NB:
The white NA got another Turbo, a Borg Warner EFR 7670. At 1.5bar the fuel pressure got to low so we have to upgrade the fuelpump.
The green NB got problems with the ignition. We have to change the sparkplugs to a higher heat value.
But the rest of our cars performed pretty well and we saw many other MX-5 on the track. We are happy to MX-5s on the racetrack.
Some impressions:
Best regards
Guido from SPS
Re: SPS Motorsport
#23
Here we have one of our biggest customer projects this year. A MX-5 ND RF with a Rocket Bunny kit and turbo conversion. A stunning car...
- Rocket Bunny kit
- Work Rims
- Nankang AR-1
- SPS coilover customized
- BBR GTi turbo conversion
- Zymexx exhaust
- CAE shortshifter
- Recaro Pole Position seats
If You have questions about the car or something different, just ask me. ;)
Best regards
Guido from SPS
Re: SPS Motorsport
#26
This year the world is celebrating 30 years of Mazda MX-5. So Mazda Germany had the idea to pay tribute by braking a record.
The idea was to drive as many corners as possible in 12 hours. The perfect job for a MX-5 NA.
So Mazda Germany came to us to get a red NA 1.6L prepared for the record. The limit was the power of the engine had to be stock.
So we installed these parts:
- engine oil cooling kit
- 6 speed transmission with gearbox oil cooling kit
- miataroadster short shifter
- Torsen-LSD with differential oil cooling kit
- SPS roll bar
- Sparco steering wheel
- Sparco Sprint seats
- Schroth racing 4-point harness
- StopTech 4-piston 286mm Big Brake Kit
- BC Racing ER-series suspension
- ATS DTC 15" rims
- Competition Clutch Flywheel and Stage 3 Clutch
- custom exhaust
- custom rallye headlights
Then they set the record in the austrian alps. Mazda Germany also produced a YouTube series about that record. We are very proud to be part of that whole operation.
YouTube: https://www.youtube.com/watch?v=s79TXUR ... -n&index=5
Press: http://japanesenostalgiccar.com/mazda-m ... -12-hours/
Best regards
Guido from SPS
Re: SPS Motorsport
#29
This is the car of a good friend of our company. The look of the car is really cool, but the engine is a tough one.
A BP block, reamed to 2 liters with an individual throttle body, race header, adjustable camshaft gears, race camshafts, revving to 8600rpm producing 230hp.
The sound the engine produces, is incredible! It screams like a race car! I think the owner, Jean Claudio Flensberg, has a good taste. ;)
Parts:
- 2.0L reamed BP block
- ARP head stud kit
- JE pistons 85.5mm
- K1 conrods
- ACL bearings
- adjustable camshaft gears
- race camshafts
- Supertech valves with Supertech valve spring kit
- Jenvey ITB
- Racingbeat exhaust header
- BC-Racing coilover
- Nardi deep corn steering wheel
- Recaro Profi SPG seats
- Takata harness
- SPS Extreme rollover bar
- Rota Kyuasha 8x15 0mm offset
- Nankang NS-2R 195/50R15
YouTube:
https://youtu.be/jD34UuNXKuk
https://youtu.be/NC-b44-4vQM
Instagram:
https://www.instagram.com/naughtymiata/
Best regards
Guido from SPS
Re: SPS Motorsport
#30
This is one of the toughest conversions we ever made. A 2.5L V6 KL swap with an ITB. We had many issues with the car until it was ready to go on the street. But at the end we solved every problem and now the car runs fine. The block is bored from 2.5L to 2.6L equipped with Wiseco pistons and K1 conrods, main and conrod bearings are Toga high performance bearings. The head got solid cam followers with different camshaft and an individual throttle body. The engine produces 250hp with an airbox on the ITB and 300hp without the airbox.
Specs:
- 2.6L KL
- Wiseco pistons
- K1 conrods
- Toga high performance main and conrod bearings
- Catcams camshafts
- solid cam followers
- custom ITB
- custom airbox
- mishimoto radiator
- DIY microsquirt ECU
- Rota RKR 8x15" 10mm offset rims
YouTube:
https://youtu.be/0dfFEtwMids
Best regards
Guido from SPS
